-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   600SCi in a 25 Outlaw (https://www.offshoreonly.com/forums/baja/187095-600sci-25-outlaw.html)
Dock Holiday 05-31-2008 09:48 AM
Originally Posted by Wild Card 09 (Post 2575244)
This shot was taken just before we wound up to 84 mph.........
Today I´m going to do a run with the 32" prop.
Stephen,
Is that thing a boat or an AIRPLANE?
You are the man!:D
SWEET RIDE.
Be safe out there and keep us posted.
Dock
Wild Card 09 05-31-2008 10:40 AM
1 Attachment(s)
Originally Posted by eddie (Post 2575378)
Wild Card did you have to change any rigging from the 525 to 600??
No, the 525 was a late model (2006) with digital 14 pin harness, so it was plug and play.
Even the bolt in offshore motor mounts were so accurate that the propshaft alignment was spot on, first time!
Only a seastrainer was neccessary to fulfill the T.EA.M. installation specs.
Dropped it off Monday evening and picked it up Friday afternoon. The Mercury applications manager for Europe came by and double checked everything.
Over here, we get a two year garantee from the importer, but having seen how well my 525 ran, I doubt I shall ever need it!
Thanks Mike for the modded pic! Now the single 600 Outlaw club starts to take shape. The other 26 (600/ITS/Sportmaster) should be ready soon!
Dock, thanks. I even check that the stars and the moon are all in the right place before I let myself get up to speed.
Going from 67 mph (in a 26 foot boat) up to an 80 mph was already a big step, but every mph after that is factor ten in terms of reaction time, and boat behaviour. No space of bad decisions, but that is what makes it so exciting.
AIR TIME 06-03-2008 09:55 AM
so how did the 32 work? so you put in a 1'' spacer to much slip?84.8 is great I am sure you will be at 86 or 87.my boat hits the shop in 2weeks for extra bulkheads dyno the new set up which could put me over 700hp, also got a call on a hp 1000 that needs to be put together at a good price. but 1st the glass work has to be done.
RunninHotRacing163.1 06-03-2008 10:26 AM
Originally Posted by socalstone (Post 2575406)
Great shot.
Here it is just a little brighter- In case you need new avatar!
Nice :cool-smiley-011:
Perlmudder 06-03-2008 01:15 PM
big pimpin! man that boat looks great!
Wild Card 09 06-03-2008 04:35 PM
The 30" saw us all over the revlimiter, with the throttle only half open, running at 82.4 mph.
The strange thing is that even with the 32" I was seeing maximum speed at half throttle. Maybe it is the torque of the blower motor.
Pushing the lever to full throttle doesn´t gain any more speed. The throttle cable is correctly adjusted - that I checked first. The motor seems to run really good, and makes light work of my 25.
Whereas the 525 needs to use all of its 5350 rpm to get its best speed, the 600 does it all using its 840 Nm of torque, and delivers best at 5100-5200 rpm.
AIR TIME 06-05-2008 11:24 PM
can you try a 34 B1 or a 32 5 blade? to see if you pick up speed , so at what rpm are you wide open 84gps?
Wild Card 09 06-06-2008 01:43 PM
I was speaking to one of the guys at Mercury Racing today (at the P1 race on Malta) and they confirmed my observation that the 600 likes to run "loaded up" so as to draw on the torque. He said that I should "throw more blade at it". That will sacrifice acceleration and holeshot, but will translate into a more speed.
The 525 was very straight forward. rpm made speed, and the fine line between too much blade and dancing on the revlimiter was easy to identify.
I can`t wait to get back out on the water (next weekend).
JB4Boyne 06-08-2008 01:36 PM
Arcticfriends (Smity) here on OSO has a 272 Baja which is pretty much the same boat and he is running in the neighborhood of 1000hp. I think his best is 98mph, but he is trying hard to break the century mark.
articfriends 06-09-2008 12:04 AM
1 Attachment(s)
John,Stephen and me have compared set-ups before,I have no desire to break 100 mph anymore after running 98 last year,boat was about 3 mph past the very top of its safe zone. I'm keeping the next size smaller pulley on the shelf:sport009:,Smitty
