502 Mag vapor locking???
i have a 97 outlaw with a 502 Mag....basically it runs flawless when i first start it up and run it cold....when i sit all day and go to leave it fires right up again but when i go to take off it sputters and wont plane out....i can throw it in neutral and it barely will idle...ive been pumping the throttle trying to clean it out and it usually will kill it....it does that a couple times (2-3 minutes) and then all of the sudden it will just fire right up and run perfectly again? It also doesnt do this every time, its sporatic but always after i run it and then sit for a while. vapor locking? fuel filter? anyone had this problem or ideas where to start looking?
Service bulletin 99-07, Pump booster kit 862264A4 will fix the problem. I can get you one if you need it!
Brett |
They can't run on just air!
Yup,,, Ill bet you dont have the mechanical pump on your sea pump,,, Merc eliminated this for a short time.
If so ,,, install the kit mentioned above and all will be well !!!! |
Originally Posted by nebraskabaja
(Post 2591485)
Brett |
I'm I smooth or what! Quit cutting your fuel with biodiesel!
Originally Posted by kennyo
(Post 2591649)
Yes, Vapor locking is the problem. It is quite common on the 454-502 MPI's. The fuel boils and creates a lock in side the fuel filter and the stock pump is not enough to suck it through. This pump is a secondary pump that creates the pressure to eliminate the lock!
Brett 402-464-4791 |
Originally Posted by will22
(Post 2591575)
thanks for the help, but what exactly is this booster kit fixing? is it vapor lock or some other gremlin?
The kit will fix this problem. :cool: |
Get the kit. PBC can take care of ya!
Eddie can too, but in a different way. |
So is this problem fixed for 2000 model 502's?
Originally Posted by NKissau
(Post 2601147)
No |
Jus went through this with a friends 2000 outlaw. check your fuel pressure it could be your fuel regulator.
My 2000 29 use to do it quite a bit. 454mags, now when ever I stop I run the blower for 10 or 15 min and have not had the problem.
Quinlan |
I also have a 502 mag efi, on real hot days one engine will be very hard to start. After a short idle on the other engine it will start. I have the cool fuel system. Will the booster kit fix this issue. It seems to be a vapor lock issue. If I leave the hatch open while parked it will sometime be ok.
Originally Posted by scottc
(Post 2601701)
If you do not have the mechanical pump mounted on the sea pump the kit will help. |
Originally Posted by eddie
(Post 2598133)
If you want to double check, spin your fuel/water filter off and check the level. If this is your problem it will be down 1/4 to 1/2 inside the filter.
(Post 2591437)
my 1994 baja 454 magnum efi is having similar issues. so far noone from michigan to texas has been able to figure it out. my repair shop has replaced the mech. fuel pump, fuel pressure regulator, IAC, and water fuel sep., on wed. of this week i went on the test ride after they replaced the fuel pressure regulator. it ran great for an hour or so. the next morning i fire it up to do some checks and it ran on the hose to 150-160 degrees. i shut it down to do some things and about 30 minutes or so later i restart it and it ran for about 10-15 minutes. then the problems started again. similar to yours. the IAC opens and it falls on its face. i have a 6 page thread located here....http://www.teambajamarine.com/forum/...ad.php?t=15047 it's a LONG thread. this has been going on for 2.5 weeks. its driving me and everyone else nutso. i have disregarded vapor lock because it has always restarted, but won't idle and just stalls. high pressure fuel pump reads 36psi at all times (per repair shop). this boat will idle for 25-35 minutes and then stall. this has happened 4 or 5 times since thursday morning. wednesday afternoon it ran on the water for an hour or so and did not even hiccup. me and 50 other people are stumped. any help is appreciated. |
here a old car fix on 396 402 chevy cloth pin on the fuil line they ack as a heat sink it work on a lot of race cars :hitfan:
ok still chasing the gremlin down....i have the mechanical pump already on my boat after looking into it some more. i hooked up the fuel pressure gauges to it and its showing 31psi when its running fine....after i ran it and sat for a while it started right up like normal - like it always does - but as soon as i started to take off again the pressure dropped to 20 then flat lined and there i sat....i was told 30psi was low? anyone know what they are supposed to be pushing stock?
| All times are GMT -5. The time now is 06:43 AM. |
