Boss 302 Spartech Windshield (acrylic)
Does anybody know what a used Spartech acrylic windshield removed from a 2004 Boss 302 is worth? The windshield is in perfect condition. All hardware was saved upon removal.
Originally Posted by wwwyohan
(Post 2624417)
[email protected] |
(Post 2624417)
XT |
Got your email. Shoot me a pic I'm definately interested.
Originally Posted by XT-Innovator
(Post 2626122)
I am almost positive that Spartech Marine no longer has the tooling to produce that windsceen any longer. the wings are cut from flat plex by a pattern, but the center molded piece is what will be hard to find in the future. I worked directly with Spartech on many Baja windscreen designs over the last 20+ years.:cool-smiley-011:
XT |
Originally Posted by Specialized
(Post 2637425)
I just talked to Spartech a few weeks ago and they have kept the molds for the 38 special (good news for me) I broke that center section that you were refering to on mine. If that 302 windscreen would fit I could find a good home for it
Both the 38 Special, and 302 used the same windshield as the 272, and 272 Islanders of the same model years. The problem is that the 38 Special was the first model designed and the windshield landing was only 3/4" wide for the windshield to set on. When the 302 was designed we increased the landing area to 1 1/2" wide to help with problems installing the windshields. The vertical surface that the windscreen mounts to is a narrower design on the 302, and was a different windscreen tooling than the 38 Spec. but they are very close in design. A 38 windscreen would be a loose fit on a 302, and a 302 windscreen will be a very tight fit on a 38 Spec. (if it fits at all):mad: XT |
(Post 2637605)
For them to still have the 38 molds is good news.
They are VERY helpful in having stuff made over at Spartech for anything on a Baja now that Fountain has bought them out. Under previous ownership Brunswich/Baja made them sign a contract NOT to produce anything for a Baja boat, but thankfully now that Baja has been sold all those contracts are null and void and they will reproduce parts of models that are no longer being made. Some of the problems lie though if they still have the molds. My 302 they didn't, but a good friend had one and they reproduced it from his pieces so if you break anything that is acrylic make sure you keep as many pieces as you can for them to reproduce off of and they should be able to make the part.
| All times are GMT -5. The time now is 04:19 AM. |
