-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Choosing props for a 29" Baja Outlaw? (https://www.offshoreonly.com/forums/baja/193479-choosing-props-29-baja-outlaw.html)
gbeach 08-19-2008 09:09 AM
I need help choosing the right props for my 29’ Baja Outlaw. Boat is powered by stock twin 454 Mag MPI’s. Currently I am running 25P 3 blades. They are slightly abused with some minor dings in them. I am only pushing about 4100 RPM’s with these. I am looking for some feedback to what is the best fit for this setup. I am leaning toward 4 blade props but unsure of the pitch I should use. Any suggestions would be appreciated.
jmeng 08-19-2008 09:59 AM
I responded to your other post but you should be able to turn the 25s faster than that. I would find another pair to try before spending money on smaller props. Typically the 3 blades were good props for the older 29s lower x diminsion. 4 blades will give you some extra cruising speed but cost you a few mph at top end.
XT-Innovator 08-19-2008 11:24 AM
My 2000 29ol would turn 4600 rpm with 7.4 MPI's and 25p Mirage Plus props. Are you sure you are not turning 5100 rpm's ? I traded my 25's for 24p Bravo 1's that droped the rpm to 4550 and lost about 1 mph on top end, but the 25's were to hard to get on plane on Lake Erie in 3-4 footers without blowing-out. When I tested 24" labbed props, they were the best all around prop for speed, and take-off.
XT:cool:
29KILROY 08-19-2008 11:24 AM
26 Pitch 4 Blades Labbed period.
JasonSmith 08-19-2008 03:50 PM
That is what I ran with my 454 MPI Mags. With the 310 motors I would go with 24 or 22 4 blades, labbed.
29KILROY 08-20-2008 06:17 AM
Sorry totally missed the 310hp part, in that case what Jay said.
mroutlaw_ 08-21-2008 11:38 PM
I have a set of 24P Bravo 1s. Still in the box.
P.M me if you're interested in them.
