Best prop for 23OL
What is the best prop for a 23OL. I'm blowing out coming out of the hole. Once on plane I'm fine. Just trying to get your thoughts. Thanks
Motor??
What prop is on there now?? If you are blowing out coming on plane that is odd?? Do you have the drive all the way in? Check your prop does it have damage, nicks, cracks, very rough edge? You can obviously go up a pitch and have it labbed, 4 Blade Bravo will usually give you better midrange, 3 blades usually more top end. 6.2 19 pitch 496 Mag 23 pitch 496 HO 24 pitch :ernaehrung004: |
496mag w/23pitch
Also drive all in. Nothing wrong with prop.
| All times are GMT -5. The time now is 09:54 AM. |
