-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Outlaw 33 Engine & Parts Starting $100.00 (https://www.offshoreonly.com/forums/baja/198427-outlaw-33-engine-parts-starting-%24100-00-a.html)
empire0007 11-05-2008 07:48 PM
1. Mercury 525SC complete Fresh Motor with less than 10 hours. This motor has Teague Super Chiller, Billet Aluminum MSD Ignition, Upgrade to the hydraulic Rollers / Rockers and Cams, new Polly’s, rebuilt charger, blue printed 1050 Carbs, new valves and much more. This motor has been blue printed by one of the well known offshore mechanics at So-Cal Speed & Marine. All papers and documents will be provided upon request. Asking price for the entire engine is $12000.00 Dollars -------------- 2. Mercury 525 SC Supercharger with Teague Super Chiller Intercooler + blue printed 1050 single Carburetor, Stainless Steel Thermostat housing and Intake Manifold. The supercharger has new 2 7/8” pulley and new belt. Price for the complete set $3000.00 Dollars -------------- 3. Billet Aluminum MSD Distributor with 6M2 Box and Blaster Coil $780.00 Dollars -------------- 4. Mercury 525 SC Wire Harness $100.00 Dollars -------------- 5. Alternator Bracket and a 60 AMP Alternator $150.00 Dollars -------------- 6. Mercury 525SC Starter $ 75.00 Dollars -------------- 7. Mercury 525SC / Chevrolet Big Block Bell Housing $ 100.00 Dollars -------------- 8. Mercury 525 SC Offshore Solid Engine Mounts $100.00 Dollars Each -------------- 9. Stainless Steel Water Cross over Mercury 525SC / Chevrolet Big Block $80.00 Dollars -------------- 10. Mercury 525 SC Crane Roller Rockers and Crane Roller Lifter Hydraulic $500.00 Dollars -------------- 11. Mercury 525SC / Chevrolet Big Block 8 QT oil Pan and Timing Cover $100.00 Dollars -------------- 12. Mercury 525 C Valve Covers $75.00 Dollars -------------- 13. Mercury 525SC / Chevy big block Cylinder Heads $ 750.00 Dollars -------------- 14. Mercury 525Sc / Chevy big block Balance External Flywheel $100.00 Dollars -------------- 15. Mercury 525SC Oil Cooler and Filer and Mount $ 50.00 Dollars -------------- Please ask for Mike at 310.433.5332 or email him at [email protected] there are other parts available as well
