-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   steering cable? (https://www.offshoreonly.com/forums/baja/204774-steering-cable.html)
Fixxxer22 03-12-2009 08:14 PM
steering cable?
does anyone know where i can get the size of th steering cable used on a 24 outlaw 1993. it is a teleflex setup but i cant see any markings. and i would like to order one now. does anyone know where i can find the specs?
Fixxxer22 05-28-2009 07:16 PM
any input dock?
c_deezy 05-29-2009 01:47 AM
Is it the gear rack or the coil rack? I have mine apart, if yours is the geared rack I'll look and see if I can find a part number on it.
rchevelle71 05-29-2009 06:29 AM
Cant remember exactly, but I believe the length is stamed on the cable somewhere, last 2 digits of the part # I believe, or you could just measure it.
Fixxxer22 05-29-2009 09:39 AM
the digits are worn off and i wanted to order one but not disable the boat. it is the rack and pinion. the last number is either a 16 or 18 i dont know. and i have the part numbers to get a whole helm and cable for like 20.00 more than a cable itself. all you have to do is fugure length. i only want to take it out once. it binds a little.
c_deezy 05-29-2009 12:44 PM
Here are the numbers off the one in my 240, same hull as yours.
MORSE E300619 192IN 3948
My guess is the 192IN is the length, 16 foot.
Fixxxer22 05-29-2009 03:49 PM
sweet i will order a 16 footer
Fixxxer22 05-29-2009 03:54 PM
cdeezy, you can upgrade theentire cable and helm to the rack if you want with the latest and greatest. take cable length at the end of this part number. ss141 so my cable and helm is a ss14116 look it up it is pretty cheap.
c_deezy 05-29-2009 11:36 PM
I'm going full hydro :D
AIR TIME 05-31-2009 10:24 AM
thats the only way to go:coolcowboy:, you will cut out most of the walk, can't wait to have mine done.
