-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   HP 500 carb??? (https://www.offshoreonly.com/forums/baja/208262-hp-500-carb.html)
36OutlawSST 05-05-2009 08:10 PM
HP 500 carb???
I got a 98 36 FT Outlaw with twin HP 500's and carbs are prob needin a rebuild.. So Im lookin into usin jus a street insted of marine carb.. Thinkin like a 850 CFM Barry Grant with electric choke and mech secondaries.. Think usin a reg carb be ok, see alot doin it? :evilb:
BAJA WILL 05-05-2009 11:02 PM
if you are over 250 hours you need to replace the valve springs, I'd be more worried on those than the carbs.:ernaehrung004:
Dock Holiday 05-06-2009 09:31 AM
+1
The value springs were a big problem on the carbed 500's in your year model for sure.
As for the carb itself I believe they are all pretty much the same you just have to have a Coast Guard approved flame arrestor.
JasonSmith 05-06-2009 11:58 AM
It takes all of $50 to rebuild your carbs. I wouldn't want a choke on one either.
Your best bet is to just rebuild the ones you have.
LV 05-06-2009 01:01 PM
Originally Posted by Dock Holiday (Post 2860080)
+1
I have 98 500hps as well , I had a leak down and comp test done last week and where all within 8% of eachother, how would i know if it has original springs or not? im not the original owner, I was told that they have been rebuilt, but you just never know. my mechanic did asked me if it has had a top end done, he said it sounded as though it did!, maybe im alright for this year.
BAJA WILL 05-06-2009 03:57 PM
I don't think their is a way to tell, with out replacing them. Maybe a phone call to the mechanic who did the "rebuild".:ernaehrung004: many of them can have a broken inner spring and be running fine, compression OK, and its still a broken time bomb.
paulb32 05-06-2009 10:31 PM
If you change the carbs, be sure you have the "J" tubes in the top to spit fuel into the engine if/when a float sticks. Also be sure you have the vac port for the hose to the mech fuel pump diaphragm chamber. When the fuel pump diaphragm leaks, the vac line sucs the fuel into he carb.
You never want spilled fuel in the bilge. Stick with the marine carb and beter yet simply rebuild yours to get a baseline. They are set up for that motor anyway.
