-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   30 Outlaw with twin 496HO's which props? (https://www.offshoreonly.com/forums/baja/209144-30-outlaw-twin-496hos-props.html)
Ready2roll 05-19-2009 11:15 AM
My boat is still stock with the original props. Any recommendations on a propeller change?
I have seen talk of "labbed props" What exactly is this?
Thanks for your time!
eddie 05-19-2009 08:02 PM
Give Brett at Bblades a call and you get all your questions answered. I think most are running labbed 28 unless you have the 2004 X then you might get away with labbed 30's.
redbud35 05-19-2009 08:04 PM
Your boat should have come with 28" Bravo 1's. You should be able to run a labbed 30" with no problem. Labbing is a process in which the blades are thinned, and balanced. That is the short version. In your case they can put a little cup in the tips for more bow lift. Call Brett at Bblades for more info. He can set you up right.
Ready2roll 05-19-2009 10:54 PM
Thanks for the info guys. My 30 Outlaw is a 2005 so i take it labbed 30's is what i need. I will give Brett a call.
