Blower reset popping
Well went out in boat for 1st time this past Saturday and for some reason my port blower breaker keeps popping. Has a huge draw on system just before popping. I unhooked blower motor still pops. Very confusing how could be a dead short. Anyone have ideas? I tried a new switch as well. I'm stumped, but don't really wanna fork out hours worth of money to pay a shop that really doesn't know how these boats where put together to chase it down..
Try a continuity check on the wires, that would let you know if the wires are shorted.
Originally Posted by jfm
(Post 2877079)
Yeah, ohms, use a multi-meter and ring out the wires from the switch back, with the blower unplugged. If it is a dead short it short it would read 0.000 zero ohms, dead short. If the wires are good you will get some reading to show an open circuit.
Blower motor and switch are definately good. Starboard blower on same switch works fine, but they are wired on seperate circuit. 2 seperate breakers. I'll ohm out the wires see where I am. Thanks for your help. I'm really trying to avoid running new wires, but might be my only option unless I can find the short.
Just wondering if you you checked out the breaker? It maybe faulty. Hope it works out for you.
(Post 2877896)
If it was would there be a hard draw just before it pops? |
Probably the blower motor is going bad. Either from a seized bearing or the motor windings are failed/close to failing.
Replace the blower or just use the one. I know the blowers on my boat are a M-F'er to get to. Yours can't be that much better. |
Probably the blower motor is going bad. Either from a seized bearing or the motor windings are failed/close to failing. Replace the blower or just use the one. I know the blowers on my boat are a M-F'er to get to. Yours can't be that much better. What he said! I've had these blowers seize up and melt the plastic before. |
Another thing you could try, would be to remove, clean and re-plug the main harness plug on the engines.
If I recall, power for the blowers runs through that plug. Could be a short in the plug. |
Jason I cut the wires to blower motor pulled it out and it still pops it. Put blower on a battery spins like a tornado. Wierd thing is it was working fine we stopped in afternoon after running in some rough stuff turned on blower it popped reset and blew 10amp fuse for port trim tab pump as well..Probably coincidence, but was wierd. Trim pump works fine still short in system unless reset breaker is popped. Then starboard blower works fine.
Ended up being the switch was wired improperly, which to me seems kinda strange as I've had the boat since 2005 and never had a issue til 2 weekends ago when I was in some pretty rough stuff. I guess I'll see if it does it again, but seems pretty wierd that it did it after 6yrs of course it was 6yrs with a kinked vent tube on the fuel fill too :angry-smiley-038:
| All times are GMT -5. The time now is 01:43 AM. |
