-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Baja 250ES prop question? (https://www.offshoreonly.com/forums/baja/211943-baja-250es-prop-question.html)
Biggus 06-29-2009 08:59 AM
A buddy of mine just put in a new 415 HP, Merc 502 Mag MPI CPO bobtail engine package in his 1990 250ES.
We installed a box stock 25 Mirage Plus. Only pulls 4500 rpm, speedo just a tick over 70 with one person chock full of fuel.
I think we need more rpm, 5000? Any suggestions for other 250/270 owners?
Thanks,
Kurt
BGIII 06-29-2009 12:16 PM
Kurt, I ran a 21 Mirage Plus on my 250ES w/ a modified 454 Magnum. I would think you might want to try a 23 Mirage Plus and maybe a plain 23 Mirage if they are available to test. I would agree that you should be at 5,000 RPM. I think your speed number is pretty impressive.
AIR TIME 06-29-2009 08:17 PM
Thanks,
Kurt
send the prop to bblades to have it labbed that will get you 300rpm when full of fuel and more speed, 4800 and maybe 49 to 50 with half a tank. I had the same motor but carbed in my 24ol would get 4700 with stock prop. if you drop down to a 23 4800 you will loose speed from the labbed prop but be about the same with non labbed. and forget about the speedo there off by 2 to 4 mph you need a gps speedo for true speed. I had two friends that had that boat one with the 365hp 454ran a 23 and other with the 502 he ran a labbed 25 if that helps. art kurt I never got back to you to day hahha, talk to you in the morning about the cockpit rug I will try to get it to you before you leave for out west it will be the temp rug later art
jeffswav 07-02-2009 05:23 PM
Thanks,
Kurt
Was that 70 MPH on the "Dream O Meter". You should probably have a 23 pitch Mirage on the boat. Get a GPS you will be lucky to see 63 MPH. Not trying to be a smart a-- I used to do the same thing. I told everyone my boat did 60 and when I got a GPS it really did 55. Now I got it up to 69 GPS 4900 RPM with Lab finished 25 pitch.
Biggus 07-06-2009 06:48 AM
With one person, full fuel (100 gals) and 25 Mirage Plus it ran 67.6 on gps @ 4900
I guess it's running pretty good for a stock 502
