-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Question On Thru Hull Depth Finder On 29 (https://www.offshoreonly.com/forums/baja/214995-question-thru-hull-depth-finder-29-a.html)
1fast432 08-16-2009 12:30 AM
Looking at a 29 outlaw,has a black plug in bottom between the motors. All I could figure is that its a depth finder, has a small round box on top with a wire coming out. Just not familiar with a thru hull design. Anyone use these and any problems to look for. THANKS JOHN B
PJDiesel 08-16-2009 08:32 AM
I have an "IN" hull, that may be what you are referring to. There are THRU hull, but they seem to be less common.
You can figure that out by looking under the boat, you see anything? If not, it's an IN hull. Nothing to worry about. I think it is the best way to read depth. I much prefer it to transom mount transducers.
1fast432 08-16-2009 09:06 AM
The plug is on the bottom of the boat with the round box and wire inside the boat. THANKS
PJDiesel 08-16-2009 09:39 AM
Thru then.
No biggie. As long as it was sealed up properly (like any below the water line through fitting) it should be fine.
Usually people use 5200 or similar. For the most part you had better MEAN it when you apply 5200, .........it's there to stay.
RICHARD CUNY 08-16-2009 07:16 PM
I Installed A Liversie Unit In Hull Mounts Inside They Recomend Epoxy Mine Works Great Speeds Up To 75 Mph
Rich
