Trying to install GPS unit?
On an 06 outlaw 25 where what are you guys useing for your power and your ground? In other words where are you picking up the power and ground from? This is for a Garmin 540s.Thanks in advance.
You can pick the hot lead off of the oil pressure guage, and the ground to any of the grounds behind the panel.
Originally Posted by dennis1009
(Post 2969345)
I just ran the wire to my breaker panel down below the helm picked up ground and positive there. Just use one of your acc breakers.
Does the '06 come with ACC switches? If so that would probably work if they are there and not being used.
Originally Posted by NoWake200
(Post 2970550)
(Post 2970744)
Yes this is what I did. thanks for the suggestions.
| All times are GMT -5. The time now is 09:13 PM. |
