-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   How do you remove the grills from the clarion speakers? (https://www.offshoreonly.com/forums/baja/22090-how-do-you-remove-grills-clarion-speakers.html)
dloftis 04-11-2002 09:35 PM
Any info would be helpful. Thanks!
canada 04-11-2002 10:57 PM
baja speakers
I just removed mine last night. they have a little black glue in three spots, just pull them off.
dloftis 04-11-2002 11:13 PM
wow, just pull? Do they snap back on, or do I need glue?
obnoxus 04-11-2002 11:18 PM
They are obviously different then mine then,,, I have 4 visible screws holding my calrion grills on
dloftis 04-11-2002 11:59 PM
Hmm... no screws on mine. I assumed that they just popped off or there was some kind of plastic catch, but I didn't want to break them trying.
29 OUTLAW 04-12-2002 08:04 AM
Hey Loftis,
Don't you have a 29 Outlaw? At any rate, I took mine off last year. They just popped off but it was not easy. Prepare to rip up all your fingernails. However, no screws - no glue.
CFD5 04-12-2002 08:25 AM
Mine just turn about an inch or two to the left and they come off.
dloftis 04-12-2002 09:04 AM
29OUTLAW: Nope, it's a 2001 Hammer, 7.4L MPI.
Thanks everyone for the responses!
NotTOOBAD 04-12-2002 05:16 PM
Try turning the grills left or right they should pop off...if they're real tight, a small, thin L- shaped piece of metal will go a long way on saving your fingernails...just work it in between the grill and the speaker and it will give you the leverage to gently pop the grills out over each of the catches on the speaker frame.
Took me 3 speakers to figure this out...but tthe fourth came right off!!!
