-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   thinking about picking up a baja (https://www.offshoreonly.com/forums/baja/220928-thinking-about-picking-up-baja.html)
official_style 12-05-2009 10:42 AM
Im thinking about picking this boat up, this is going to be my first boat. What do you guys think? the seller is local, so i can go see it in person. any questions i should ask the seller, and problem areas i should look for?
http://cgi.ebay.com/ebaymotors/ws/eB...tab%3DWatching
http://img.photobucket.com/albums/v2...le/baja220.jpg
Baja24 12-05-2009 12:31 PM
Hi, I had 1987 235 Force with a 454 and Alpha Drive for about 8 years. One thing to look for is Baja drilled about a 1 inch hole in the stringer about 10 inches from the transom to drain the water from the outside of the stringer to the bottom of the boat and on mine and the ones I looked at Baja did not fiberglass the hole after they drilled and will rot the stringer if boat gets water in it alot. Also check the lag bolts in engine mount, mine would no tighten up due to old age of boat no rot. I was going to go with through stringer engine mounts from Eddie Marine but sold the boat instead, wanted somethine with a Bravo Drive. I bought a 1988 Baja 24 Sport this summer and it has the holes drilled in the stringer also "no rot" and this one has the through stringer engine mounts, with a 468 chev. Fun boat, lot better hull with the 24 degree hull. Think they ran the hull that I have on the Outlaw24 to about 97. don't know about the 86, but think it is a different hull " flatter bottom" Don't know if any of this helped but thats what I ran into.
sonic69 12-05-2009 02:54 PM
Find a surveyer in your area to look over the boat. It could save you alot of money in the end.
JasonSmith 12-05-2009 02:59 PM
My Dad had a 220 with a 454 Mag scotch-taped to an Alpha. We never had any problems with it. It was the boat that turned me on to Baja's!
The boat you are looking at won't break any speed records, nor should it break the drive.
Have it surveyed by a professional marine surveyor. Rot would be my 1st concern. It is an 86. It wouldn't surprise me if it has some rot somewhere. As long as it is not in the structure of the boat I would not be too afraid.
Don't plan any real performance upgrades. The Alpha drive is a great drive, but it really isn't HP friendly. 400hp would be the most I'd want to put through the drive.
Good luck on the potential purchase!
official_style 12-06-2009 07:19 PM
after reading thru the complaint thread on teambajamarine, i definetly want to get a surveyer to take a look at this boat. how much does that usually run? what do you guys think the GPH at cruise and WOT would be with the 5.7? im going to go take a look at it this week, and if i like it in person i will need to get a surveyer to check it out.
Baja_man 12-07-2009 07:10 AM
A survey will be between 300-500.
Dock Holiday 12-07-2009 08:19 AM
Cool Boat
risky 12-14-2009 02:23 PM
Seems like a nice boat
Can't go wrong for the price if he lets it go for around 4k
