-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Stock Exhaust (https://www.offshoreonly.com/forums/baja/229671-stock-exhaust.html)
mpally 05-03-2010 10:45 PM
Stock Exhaust
We are looking to change out the stock Corsa exhaust tips on our 2004 36 Outlaw with 496's. The stock tips are not loud enough. What tips should we go with? How big of a project is this? I did a search, but most of the posts are rather dated. Any help is appreciated.
wjb21ndtown 05-03-2010 10:48 PM
Can't you leave the tips and modify the mufflers or tips? It seems to me that if volume is all that you're looking for, you should be able to do it w/o changing the tips.
sonic69 05-03-2010 10:55 PM
I put Eddie marine tips on mine. It's not a hard job at all. It definetly made a big difference in sound. I would definetly do it.
Nightlife1970 05-03-2010 11:18 PM
Just about any tip of the right size will work. If you have the Corsa tips I had you can drill out the rivits that hold the last baffel on and remove it. That makes a big difference in the sound.
Otherwise I just saw some tips that Irish got from Hardin. Nice looking tip that you can use the slip in silencers on. I don't think he spent a lot on them. I think mine are Eddie Marine tips, again if it is 4" exhaust any 4" tip will work.
mpally 05-03-2010 11:51 PM
Has anyone used these tips?
http://www.danamarineproducts.com/Pr...b-0d352a2e415b
Would these work in our application?
sonic69 05-04-2010 04:33 AM
They should do the trick.
JasonSmith 05-04-2010 03:33 PM
2 Attachment(s)
I prefer these by IMCO.
never enuff 05-04-2010 04:37 PM
I think if you buy the tips from Eddie, the flange on the new tips will not use the same holes as the Corsa tips. You will have to fill the old holes and drill new ones.
Jay
mittens 05-07-2010 11:21 AM
i want mine to be louder too, but i can not see any type of silencer in the stock ones.
emilsr 05-07-2010 12:04 PM
Corsa makes some very nice unmuffled tips with a clamshell internal flapper....much less clanging than most brands. That's what I'd go with and they're reasonably priced. It's an easy job; even I could do it. It's also a good opportunity to do a better job of sealing the wood in the holes than they did at the factory.
