25 outlaw prop ?
running a 502 and using a 23p mirage plus labbed by b blades runs great but keep bening it second time on this prop low water in louisian = stumps at the docks . what 4 blad prop would i run if 200rpm were added to the 23p 3 blade?
I think most 25's with stock 502's run 22 Bravo's for a 4 blade set up.
24p Bravo
Originally Posted by mpally
(Post 3108125)
Originally Posted by caseyh
(Post 3108099)
John i just can win this year!!!! No more labbed porps after this one didn't have this problem untill it was labbed but it works awsome when it's not bent. 200rpm's were added to the 23p so wouldnt that make it a 21p ? if what i was toldwas right that every degree was 100rpm. if thats the case with out buying and tring a 22p 4 blade do you think ill hit the 5100-5200rpm mark ?
If you don't want a labbed prop I'd be looking for a Rev 4. You'll lose less top end than with the Bravo as it carries the bow better. Plan on about a 300rpm decrease at WOT when compared with the same size stock M+.
buy a stock rev 4 from bret start with a 21 and if your spinning to high send it back and try a rev 4 23. I would think a 502 merc motor would turn a 23 rev, my 24 turned a stock mirage 25 prop fine until I reworked the motor to 600hp:evilb:.then 650hp and so on. but brett mit send both out to you to try. good luck
