Help! Port engine has a high speed miss
I have a 30' OL with the twin 496 HO's
Yesterday while out on the boat the port engine began "popping" at around 4000 and above RPM. At lower RPM's it seems fine. Both engines have 140 hours on them. To my knowledge the fuel filters have never been changed. STBD engine runs fine. Any ideas on what I should be looking for? |
change the fuel filters first,,
Ignition probelm. Check wires, change Plugs, Check Cap & Rotor.
When it does it how much does the tach drop?
Originally Posted by TWIN-SPINS
(Post 3112805)
Originally Posted by 29KILROY
(Post 3113273)
Originally Posted by Expensive Date
(Post 3113314)
http://www.offshoreonly.com/forums/g...4600-rpms.html
You should change your fuel filters but doubt it is fuel.If the tach is dropping that fast you are probably losing power to the ignition system.Linked a thread had similar problem a few years ago. But you really have to go back to basics sometimes but I believe its ignition. |
Originally Posted by Ready2roll
(Post 3112552)
Yesterday while out on the boat the port engine began "popping" at around 4000 and above RPM. At lower RPM's it seems fine. Both engines have 140 hours on them. To my knowledge the fuel filters have never been changed. STBD engine runs fine. Any ideas on what I should be looking for? miss the 496HO's.... lol |
Did you figure out what was causing the issue? We are experiencing the same thing at 4000 rpms, but without the rpm drop. We just have a popping sound that starts around 4000 rpms. Motors run great otherwise.
Check the Fuel pump, my brother just went thru/ this last week!
Have someone check your injectors as well...A friend of mine just went through this as well.
Originally Posted by mpally
(Post 3167633)
found the port prop brass insert bad and would knock at around 4000 rpm and the noise would transfer up the drive and in the engine,sounded like the engine was going to come apart. |
| All times are GMT -5. The time now is 12:45 AM. |
