-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   36 Outlaw actual weight? (https://www.offshoreonly.com/forums/baja/230890-36-outlaw-actual-weight.html)
paulb32 05-19-2010 10:35 PM
Wondering if anyone has run their 36 across a truck scale for actual weight? I know the brochure says 8300 lbs. I've gota 98 36 wth 525sc's, silent choice, hyd steer, air/heat, vacuflush, micro, tv. I'm coming up with low 9's in weight based on 2 different truck scales (already deducted trailer & gas).
Dock Holiday 05-19-2010 11:09 PM
When my 36 was lifted off the flat bed at the dealer by a crane the scale on the crane was right at 8500 lbs. It had all the options including 500EFI's and XZ drives.
GETTINBYE 05-20-2010 06:26 AM
I weighed my trailer empty and later the same day the boat on the trailer on the same scale. The boat was very low on fuel, no water, and only essential other items. Mine is a fully optioned 1999.
The boat weight figured out at 9460. Trailer and boat at 12460.
All weights obtained with the trailer unattached from the truck.
Hope this helps.
Mark
