-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Baja Tachs (https://www.offshoreonly.com/forums/baja/249174-baja-tachs.html)
jvcobra 03-11-2011 10:00 AM
Baja Tachs
Both of my tachs are not operating correctly. Is there a place I can send them for repair or buy some new or takeoff Baja ones?
Irishtornado 03-11-2011 12:06 PM
Which ones are they?
Boomer35 03-11-2011 12:14 PM
i have 2 gaffrig ones i just took out
fleg1 03-11-2011 02:46 PM
Same here I have 2 yellow ones!!
crayolacrazy 03-11-2011 06:23 PM
google skipper buds
jvcobra 03-12-2011 06:02 AM
You know, I am not sure of the brand. They have a white background and say Baja on them. Boat is under cover so I can't look for manufacturer. I'll have to check in the Spring but I want to say they have gariff on them.
bajarick 03-12-2011 07:19 AM
cALL Livorsi Marine they have them and repair
them also.
JasonSmith 03-12-2011 08:38 PM
Livorsi can fix them, but what are they doing that makes you think they aren't working correctly?
I've seen my share of guys who think their tacks are broken when all it turns out to be is spark plug wires laid too close to the tach signal wire on the distributor.
Smitty 03-12-2011 10:08 PM
Highly unlikely that BOTH tachs are internally malfunctioning at the same time. You most likely have a wiring issue. Start looking for loose grounds and check the igntion kill switch. Both tachs go thru there.
