-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Battery cable (https://www.offshoreonly.com/forums/baja/249738-battery-cable.html)
40j4a 03-20-2011 06:05 PM
Battery cable
I was wondering if anyone knows the battery cable size in a 25ol? I'm going to install a 2nd battery and need to get cable on order. Boat is a state away at the moment......Thanks
Baja_342 03-20-2011 08:00 PM
Ate you adding another switch? Whenever I've added batteries I just used whatever autozone/walmart/meyer had. Nothing special if you're piggy backing off existing battery.
40j4a 03-21-2011 05:07 PM
Yes I'am installing a switch and isolator. The boat came with a single battery, no switch. I'm adding approx. 5 feet of extra cable length so I'm going to install larger battery cables.
Nightlife1970 03-21-2011 09:45 PM
4ga should be plenty.
40j4a 03-22-2011 11:04 AM
Thanks.......
US1 Fountain 03-22-2011 01:15 PM
Chit can the isolator and use a combiner. Doesn't require any alt rewireing and you don't have a voltage loss with a combiner as the isolators do.
Isolaters are yesterdays technology. ;)
Are you just adding a 2nd battery for backup?
2AWG is common size battery wire size. Amp load and wire lenght determines wire size, not what is available at your local autozone.
40j4a 03-22-2011 03:56 PM
The 2nd battery is for a stereo system. Do you know how much loss you have with an isolator? And yes marine cable will be used.
US1 Fountain 03-22-2011 04:31 PM
http://bluesea.com/viewresource/58
http://bluesea.com/products/7610 $84 thru boatfix
40j4a 03-22-2011 06:57 PM
US1 thanks for the ACR info. I don't know how I missed this when researching the 2nd battery install. Seems that Blue Sea has this figured out. I like the idea of no switch to mess with. Even though I already have a switch and isolator this seems like a better solution for my situation.
