-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   25 o/l depth transducer mounted? (https://www.offshoreonly.com/forums/baja/251580-25-o-l-depth-transducer-mounted.html)
4Lance 04-16-2011 07:36 PM
over the winter i ordered a new depth sounder to change out the stock one gaffrig/livorsi style the main reason i wanted a chrome bezel and plus my transducer is just flopping around under the engine since the glue must have broke off. still worked but flashed on and off sometimes.
i ordered a angled puck style and now after looking at the sides i cant tell where it was mounted before ?? i thought it was on the slope now im thinking maybe it was on the flat part in right under the engine?? so i might get the one that was supposed to come with it ?
Could you guys give me a measurement or picture to where yours are mounted on your 25 outlaws?? please
anyone else using the gaffrig/livorsi style one?
Baja_man 04-17-2011 08:07 AM
Will take photo today...my engine is out at the moment.
4Lance 04-17-2011 04:43 PM
thanks
Baja_man 04-17-2011 05:01 PM
He is picture, you can see the transducer on the floor.
http://i803.photobucket.com/albums/y...l/P4170323.jpg
Irishtornado 04-17-2011 05:34 PM
Clean that bildge!!!!
I hope your pulling that extra 40lbs of scrap off your transom.
fireguy 04-17-2011 05:39 PM
I wish I would have when i had my engine out last year.
Baja_man 04-17-2011 05:42 PM
If it ever quits snowing I could get in there and do some work. And yes, as much as I want to keep the exhaust diverters I've been warned several times that it is a bad idea now to keep.
Irishtornado 04-17-2011 06:17 PM
Loud Pipes save lives! CMI makes some nifty slip on mufflers that open as you go for those peskt tree hugging liberals!:lolhit:
4Lance 04-17-2011 09:43 PM
awesome pic so why is your engine out??
Baja_man 04-17-2011 09:45 PM
Adding a little more power to the 496 and headers.
4Lance 04-17-2011 09:49 PM
my transducer is flooping around back there in that area i wonder if thats where mine was from the factory the glue came off the puck and the fiberglass it was floating around the bilge been like that since i got the boat last year
c_deezy 04-18-2011 12:56 AM
There should be a place on the bottom of the hull where there is no coring. It will be concaved out, that is where you should mount the transceiver. I used 4200 when I did mine last year.
Baja_man 04-18-2011 04:46 PM
I would think all 25 Outlaws were very similar in the location of the puck. If you can reach it and its dry, 4200 it in.
4Lance 04-20-2011 09:48 PM
well if anyone needs a brand new angled puck XAP 9 20 humminbird shoot thru http://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MESELX:IT
