-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   33 Outlaw with boxes and big HP? (https://www.offshoreonly.com/forums/baja/251695-33-outlaw-boxes-big-hp.html)
JaayTeee 04-21-2011 12:32 PM
Originally Posted by Knot 4 Me (Post 3382798)
OK, found some pics of the boxes. I doubt when he said "alignment problem" that it was the carrier bearing inside the box. You would think that would just affect the ease in getting the drive to mount and the spline wear on the drive's driveshaft. The driveshaft from the box to the flywheel is a flanged coupling at both ends. So is the phasing you are talking about between the box driveshaft and the drive's driveshaft? I'm surprised Stelling's does not balance those driveshafts.
Go down to the bottom of this link, it gives an illustration
on phasing.
On their jackshft engines and staggered ( driveshaft models) they( merc) do recommed phasing the driveshaft with
the outdrive u-joints. (which I started to do after reading it in the latest manual I got.)
http://jniolon.clubfte.com/driveline...nephasing.html
Knot 4 Me 04-21-2011 01:24 PM
on phasing.
Easy enough to understand. Thanks for the link!
offshorexcursion 04-22-2011 09:48 AM
Great info and some nice set ups. I just wish I had some drives on the back of my boat to turn some good numbers! This thread is keeping me motivated though
Knot 4 Me 04-22-2011 01:30 PM
BTW, saw the boat owner last night as we were helping another buddy re-bunk his trailer and he said the motors are now 522's. That helps to explain the 605 HP.
Keith Atlanta 04-22-2011 09:09 PM
Whats your 33 run with 830 HP?
offshorexcursion 04-22-2011 09:41 PM
I do not know since my drives did not hold up long enough to find out!
I have seen 95 on gps EVERY time I push the sticks forward for a few seconds. This is FULL of fuel, 4+ people, 2 full coolers, all gear for a 4 day weekend sleeping on the boat! Never tried empty with just me in it.
According to J T , Crayolacrazy , BBlades and others I have lots of room to work with props. Currently running 30" stock bravo 4 blades turning out.
Looking forward to some new stronger drives, maybe bravo arneson conversion or the new imco's they are keeping secret. Then some aggresive props and hopefully triple digits!
Crazy Dayz Skater 04-24-2011 11:18 AM
Just bite the bullet and buy a pair of SCX,they have been out long enough,and still no upper gear failures,Bolt a pair on and go enjoy that horsepower.(good talkin to you yesterday,lookin forward to seein you at the shootout)
offshorexcursion 04-24-2011 12:52 PM
Yeah it was nice talkin! Some scxs would be nice!
crayolacrazy 04-24-2011 08:23 PM
I run xz uppers imco lowers , change fliud about every 5 weekend or after a hard weekend . I also run amsoil 75 /90 marine .
offshorexcursion 04-25-2011 01:32 PM
How many hours can u go between rebuilds? I could only make it 30 to 50 going easy on my imco SC drives. I normally run over 100 hours a summer so making it a couple years without touching drives would be nice!
