-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   How much Oil? (https://www.offshoreonly.com/forums/baja/253370-how-much-oil.html)
kragar 05-11-2011 05:27 PM
How much Oil?
How much Oil does a 502 in a 25 Ol (1999 Fuel Injected)take. Just changing the oil for the first time since I have owned it. Also, it uses oil. Seems every day out it needs a litre of Oil. Boat runs strong, Oil pressure is only 35 at WFO and about 8 at idle after a good run and will climb to just over 10 at idle. Still will show just over 70 on speedo and run 5000 with a 23 M+ prop.
pagerboy 05-11-2011 06:27 PM
7 qts. I think I would start saveing money for a new motor!http://www.perfprotech.com/store/App...l-capacity.pdf
mpally 05-11-2011 06:31 PM
We had a 25 with a 502. Ours used oil as well (502's are known for that). I would be more concerned with the oil pressure. What type of oil are you using?
Smitty 05-11-2011 09:10 PM
Time for a rebuild. You should have no less than 20 psi after a hard run and you should be around 50-60 psi at wide open at top rpm.
Irishtornado 05-11-2011 10:06 PM
I'd verify your sending unit is not bad or your gauge with a mechanical, but if you only have 10psi of oil pressure it's time for rebuild.
kragar 05-12-2011 06:40 AM
Yes, gonna check with a mechanical guage 1st. The guy who had the boat before me ran amsoil 10w40. I just switched out to 20w40 merc Oil and used the K&N long oil filter. Where is the sending unit located on the 502?
obnoxus 05-12-2011 07:23 AM
Down by the filter pad adapter.
I had one that dropped like yours, ( actually to 0 ),,,,got lucky and ended up being the sending unit.
Hope you are as lucky !!!!!
SmurfOnABoat 05-12-2011 08:28 AM
I had a bum sending unit that was causing faulting readings, and would fluctuate sometimes. I would verify with a oil pressure gauge before you worry about a new motor.
Rule of thumb is 10psi for every 1000rpm of engine speed. At least 10-15psi at idle, generally it is higher than that though.
And what oil are you using? You should be running a thicker oil such as 20w50, not traditional car oil such as 5w/10w-30/40
kragar 05-13-2011 08:10 AM
20w50 in it now with a K&N filter
Irishtornado 05-14-2011 03:13 PM
You should be running 50-60lbs of oil pressure while underway.
