-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Baja's At Shootout (https://www.offshoreonly.com/forums/baja/261134-bajas-shootout.html)
Quinlan 08-29-2011 05:15 PM
Originally Posted by JasonSmith (Post 3489860)
She's a bad mammer-jammer. 94mph is what he said it runs now.
I believe he had the motors re-did in 09 when I ran the Shootout. I am thinking they have been re-cammed & may have some head work done to them. Otherwise they are Merc 575SCi's.
He said it ran better with more people in it. I was willing help a brutha out!
Good run for sure John
JaayTeee 08-29-2011 08:10 PM
:D
Originally Posted by JasonSmith (Post 3489762)
That would be JayTee on here.
I was running with a pretty rough crowd this weekend,
and after the last sub 90 mph run, one of the guys said
" the 90 mph club called, and they want their stickers back":D
I dont know if it was the air or the driver, but the boat should have ran better.
JasonSmith 08-29-2011 11:03 PM
Originally Posted by JaayTeee (Post 3491301)
:D
HA! That's fantastic! As far as I'm concerned once you're in, you're in for life.:drink::drink:
Bajapred 08-30-2011 07:43 AM
Yep, just like do'in a fat chik, once your in the 200# club, your in for life!...same with Mile High club & Hair Club for Men..All life long memberships!...jood job jt!
Keytime 08-30-2011 09:06 AM
3 Attachment(s)
Bajas at the start:
JaayTeee 08-30-2011 05:55 PM
Originally Posted by boatman22 (Post 3491022)
I need to get ahold of him to see what upgrades he did.....:coolcowboy:
Dart Iron Eagle heads, ( kept iron heads to keep from
screwing up the center of gravity of the boat)
hyd roller cam and ECM recalibration.
Dean Gellner built and supplied the heads, reflashed the ecm's, and supplied the camshaft.....it's his recipe.
I had the block honed, decked, ringed and bearinged
it ( was able to go back to stock clearances) and
reassembled it, used MLS head gaskets, new rockers
pushrods, timing chain, morel lifters, ARP head bolts.
The accessory mounting bolt holes at the ends of the head
have to be drilled and tapped to 7/16 fine thread, and the
factory engine lifting hooks are no longer usable due to
that most aftermarket heads dont have the intake bolt holes
between the intake ports.....I ended up making a set of plates
that bolt to the ex side of the head for lifting purposes.
That's it in a nutshell.
Deans # is 216-398-8500
boatman22 08-30-2011 06:20 PM
thanks JaayTeee...i talk with Gellner about striping my blowers this winter. Did you have yours stripped?
JaayTeee 08-30-2011 06:25 PM
I havent done anything to them, except change to oil
every year.....it's on my to do list though.
Anchorman 08-31-2011 01:04 PM
JT's boat looked good on the water we went by just before ran. I have some pics but need to down load them off the GF's Camera.
