-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Fuel Lines on 36 Outlaw (https://www.offshoreonly.com/forums/baja/262949-fuel-lines-36-outlaw.html)
charlie boy 09-25-2011 05:14 PM
Hi there,
Looking for a bit of advice, i am looking to change the fuel lines on the my 36 outlaw to 10mm fuel lines, i have just installed 2 raylar 600 engines and it is recommanded to up the size if them, so hoping so may able to point in the right direction as to where they go to on the fuel tank and hoping they go into a plate that is removable hopefully! Thanks for any help in advance:coolcowboy:
obnoxus 09-25-2011 05:38 PM
open the access panels in the floor
Smitty 09-25-2011 05:43 PM
There are access panels in the floor under the back seat. You might want to remove the anti back flow valve also as that restricts fuel delivery.
bajabob 09-25-2011 06:26 PM
i had eddie young make me a new one.the old setup the presure would only go to 5pds . i install the new lines 1/2now it at 8pds wot
charlie boy 09-26-2011 01:15 AM
thankyou for the responses, i did look in the access panel on the floor by the front seats but couldn t see much ,and was not sure if there was one under the rear seat as my boat has a water tank in the middle under the seat if there is one there, it should make it quite easy for access
WOTW2E 09-26-2011 08:46 AM
FWIW - The current lines should be .375" which is 9.525 mm. Seems like a lot of work to go to a 10mm for less than half a mm in hose diameter. I would guess there is that much variance in the production process of the hose.
charlie boy 09-26-2011 11:44 AM
The lines when we measured the bore were 8mm, the lines recommended for the engines need to be 10mm, i would rather not do them but dont want any problems of running lean, so best not skip this, thanks for your replys so far
bajabob 09-26-2011 03:08 PM
charlie talk to eddie he help me out big time made a tube for gas tank. very smart person.told me all the things to do to setup my fuel lines i have 718hp dyno http://www.youngperformancemarine.com/index.htm
charlie boy 09-26-2011 04:34 PM
thanks Bob, may well do that just that i am based in the UK, but if no luck, he will be 1st to call, thanks again
bajabob 09-26-2011 04:34 PM
here my a/f box http://www.amazon.com/Innovate-LM-1-...f=pd_rhf_p_t_4
