-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   little bubbles/ blister on hull (https://www.offshoreonly.com/forums/baja/263117-little-bubbles-blister-hull.html)
conneroutlaw 09-28-2011 02:07 AM
What causes little blister or bubbles on the hull?
Is it a real bad thing?
Can they be easily fixed?
How do you fix them?
They are about the size of the end of of pencil eraser.
kragar 09-28-2011 07:56 AM
beginning of Osmosis. From boat sitting in the water. Water penetrates the Gelcoat then swells with the fiberglass and can't get back out of the gelcoat. Proper way to get rid of it is to have whole bottem of boat sanblasted in the fall and leave it open for the winter and in the spring, have it sealed and re-sprayed. Or blast and bottem paint(will hurt resale)
obnoxus 09-28-2011 08:10 AM
My old 272 got them where it sits on the trailer carpet.
The only way I knew was I jacked it up to wax under the bunks.
I bought it new and it was covered under warranty,,,,,but what a project it was to fix.
P.S. it was a 97 as well
fountainfan42 09-28-2011 08:52 AM
The only way I knew was I jacked it up to wax under the bunks.I bought it new and it was covered under warranty,,,,,but what a project it was to fix.
or buy some bunk slides ya cheap azz :eek::drink:
have a meeting/Lunch at the White Horse ya'll around the area today :coolcowboy:
kragar 09-28-2011 09:06 AM
Mine was a 97 Hammer. Water line down had them. I went through the whole process above, but I bought the boat knowing this needed to be done and discounted the price to have it repaired. To be quite honest, if you trailer the boat all the time and plan on keeping for a long time then I would bother fixing, but if you plan to re-sell the boat in the next year or 2 then it will need to be done.
t500hps 09-28-2011 09:16 AM
remove gelcoat, let it dry out, re-gelcoat.......yes it's kind of a big job. It hurts performance and kills re-sale.
US1 Fountain 09-28-2011 10:45 AM
Mid 90's Bajas had problems with blistering. If left unchecked, it'll only get worse.
obnoxus 09-28-2011 11:05 AM
Close,,,,,University Park
Your having a meeting at the White Horse and Im the cheap ass !!!!???? :lolhit::evilb:
fountainfan42 09-28-2011 11:38 AM
lets just call it a meeting and she has such pretty eyes :eek: any nice hotels close by or its off to the Ameristar Casino/hotel in Gary :drink::drink:
gotta love EHarmony & Christiansingles.com
obnoxus 09-28-2011 12:09 PM
I figured you were up to something like that !!!!
puzzleboy 09-28-2011 09:32 PM
Never even thought of that....
puzzleboy 09-28-2011 09:34 PM
What are bunk slides?
Perlmudder 09-28-2011 09:38 PM
we had it happen, twice, first time they fixed them, the whole sanding them down, then letting them dry, and patching them. But then they never matched the gel colour well. After the first repair did not stick, the boat ended up going back to the manufacturer and ended up getting a whole new hull.
obnoxus 09-28-2011 09:45 PM
Teflon strips
conneroutlaw 09-29-2011 02:18 AM
bubbles
thank you for the insight, doing some research, that is what i found to do. I too don't like bottom paint
conneroutlaw 09-29-2011 02:20 AM
i think i will be doing that in a few years, not this year, how long do you have to wait for drying time
conneroutlaw 09-29-2011 02:23 AM
i plan on trailer it all the time, it sits in my back yard. and i do plan on keeping for a long time. so it may take me a while to have it done
conneroutlaw 09-29-2011 02:27 AM
from what you are saying , i better get it fixed soon. to bad it isn't under warranty, but if those years had a bad run, then they should still, fix it and made it a recall. but since the company is bought by fountain, i am **** out of luck. and baja would probably have laughed at me also if i brought it up now
obnoxus 09-29-2011 07:04 AM
http://cgi.ebay.com/ebaymotors/NEW-B...item3cb4089d56
puzzleboy 09-29-2011 08:59 AM
Can't see how the bunk slides would work. If you dunk the trailer and retrieve the boat, they're wet, obviously. And with 5000 lbs of boat sitting on them, they're not going to dry out between the slide surface and the hull surface. How is that different than carpet, except for slightly less water?
Unless I'm missing something.
kragar 09-29-2011 09:13 AM
Agreed, but I suppose every little bit helps. Yould remove all carpet and go with 6 inch wide teflon I suppose.
US1 Fountain 09-29-2011 11:04 AM
Wood and carpet act like a sponge and hold the water in.
The slides don't hold water.
obnoxus 09-29-2011 04:37 PM
And pray to GOD your winch strap never brakes !!!! :evilb:
fountainfan42 09-29-2011 08:37 PM
you should have addtl straps and safety chain hooked on your boat anyways :coolcowboy:
Wildman_grafix 09-29-2011 08:39 PM
They are not designed to hold the boat, use a separate strap to hold it.
obnoxus 09-29-2011 09:50 PM
who does that at the launch ramp !!??
fountainfan42 09-30-2011 05:48 AM
we do & put 2 on the stern & 2 on the bow and pull the drain plugs:party-smiley-004: that ramp by you at Pastrick is awesome :drink:
obnoxus 09-30-2011 08:11 AM
I meant backing down or retreving,,,,,,,, but you get what I mean !!!
