I can not believe that Mercruiser still can not address this tiller arm and pin situation.
I had a serious accident 30 years ago with a stock small block 19 footer at 60 mph on a small flat lake because of the tiller arm splines stripping off. After researching the new design and change of the design from a spline to a square I realized it was a design flaw and had Mercury cover all my repair and injury expenses. Anyways the fact these are still getting dangerously washed out at 300 hours is unacceptable from my point of view. |
Originally Posted by baja25sst
(Post 3522588)
As I said, did mine (cable assist/hydraulic assist)-just not the full system. THe one problem I did have or continue to have is that at slow speed pulling into a slip or dock that the amount of fluid is insufficient to steer properly. The guy at IMCO said something about drilling out the power steering pump hole somewhere to allow more fluid to go through? Have not done that but going to do so. (maybe there is just another pump aftermarket that would make it work well?). I still love it, drive is solid!!
If your keeping your boat stock, why waste the money? I added the full Imco dual ram set up on my baja only as a necessity, at 80 mph the drive started to dance around, The imco set up created a very stable ride at high speeds, But again your safe under 70.
Originally Posted by pacalim1965@yaho
(Post 3526327)
65 MPH was the breaking point at Baja Marine, and 70 MPH is the Mercury number.
XT |
Might as well put air bags in it as well .....better safe than sorry!
(Post 3529484)
:Whatever: |
| All times are GMT -5. The time now is 12:10 AM. |
