Originally Posted by Sydwayz
(Post 3525936)
I believe all 496s shipped with oil drain hoses. It's the ONLY way to change oil, ALL the oil.
You can order the oil drain hose kits from Mercury. Www.bammarine.com If they connected the hose the only way to use it would be to drill another drain plug up from the keel. |
Originally Posted by US1 Fountain
(Post 3525885)
You can find that same pump many places for way less than that price. I bought 1 2 weeks ago for $50, never used, off Craigslist. :)
Other members have drilled a couple extra drain plugs a couple inches up, that they only use for when they change the oil. There are pictures of such on here.
Originally Posted by TW720HVY
(Post 3528514)
Thanks for the heads up, I will keep shopping around for one then.
my islander does have the stringers in it. There is barely enough room to see the bilge pumps under the engine let alone get a hand under there. I am going to have to pump it out through the dipstick. I ordered one of those pumps should be in soon. I called merury direct and the guy I talked to said they recommend synthetic now no matter how many hours are on the boat. Like the earlier post he said 20w-40 is in mercury brand is what they reccommend.
but he said off the record that any quality 20w-40 would work amsoil, mobil one, royal purple, ect. He said they reccomend there brand so that no one uses below grade oil. |
| All times are GMT -5. The time now is 09:15 PM. |
