stabilizer in fuel
Winterizing my boat today. I have a 496ho. I put some stabilizer in my fuel tank. Not sure if I put the exact recomended amout based on my fuel gage not giving my an accurate reading. I put the muffs on and started the motor to heat the oil up for the oil change. The motor ran great for about 4 minutes. Then it started sputtering and eventually would shut off. I tried reving the motor and it would just stall it. Evenually it would not turn over at all. Is it possible I put to much stabil in the tank? Just trying to figure out what I might be getting into here.
Originally Posted by uptick
(Post 3534602)
I may be wrong, but I'd find it hard to believe you started having these problems due to stabilizer. Let's say even if you doubled the amount that was required, I cannot see it causing these issues. Anytime you add stabilizer to any vehicle, you should run it so it makes it's way through the whole system.
Boat on the trailer???you might not have enough gas in the tank...
I even went over and put 20 gallons of gas in it just incase and it still would not fire. The only time I had something simmilar to this happening before I had to replace the air idler regulator. The motor is still under warranty so I may have to drop it off at the dealer.
May have had some water in your fuel from condensation.
Originally Posted by rgrgoog
(Post 3534711)
I'd drain your tank, change your fuel filter, and put premium fuel in it the next a few times just incase there's a little sludge in there from the bad gas. Hopefully that will fix your problem. It worked for me. |
IDK about gas going bad that fast. I have not run my boat since the middle of July. Both motors fired up and ran no problems. Ran them both for about 1/2 hour to get them warm so I could run antifreeze through them.
I think it's coincidental timing. These boats hold enough fuel that I doubt even a few gallons of stabilizer would cause that.
Try to use one of the stabilizers that treats ethanol issues also, like Startron. |
The fuel in the boat was in there from about 2 weeks ago so I dont think it would be to old, plus it had a little stabil in then and ran fine. I looked at the 496 manual and the symptoms seemed to have narrowed it down to the air idler control sensor. It seems like a simple fix since its just under the motor cover. I had this problem on my old baja and it was acting the same way. The good news is the motor is under warranty. I guess well have to see when I drop it off this week.
| All times are GMT -5. The time now is 03:02 PM. |
