props
How can you tell if your prop is cupped or not?
Also, if they are cupped can you still use the trim on your out drive and bring it up alittle to gain speed? |
You can see and feel it. It's literally cupped up on the trailing edge.
Yes, you trim as usual. With the proper cup you'll be carrying the bow much better and the boat should respond better to trim. |
Originally Posted by Hook'em
(Post 3644672)
| All times are GMT -5. The time now is 05:24 AM. |
