-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Swim ladder?? 342.. (https://www.offshoreonly.com/forums/baja/274333-swim-ladder-342-a.html)
mittens 04-12-2012 03:42 PM
Swim ladder?? 342..
So the ladder on my 342 is SHORT.
are they all like this? and has anyone replaced it with a longer one?
mine the bottom step is in the water but only by about 1 foot, the second step is about 2 inches under water...
baja pete 04-12-2012 05:17 PM
The 342 has to have the worst ladder I have ever used.
Pete
pagerboy 04-12-2012 05:20 PM
does it have three or four steps?
mittens 04-12-2012 11:16 PM
Three one above water,
One 2 inches below,,
And the last about 12-14 inches under water...
A forth out make it maybe normal
Keith Atlanta 04-13-2012 08:43 AM
I bought a 4 step off eBay. They fit. You have to slide it all the way up and grind 1/4 off the door cover for them to fit around a little of the ladder frame. Its cut already anyway...
For safety sake I have 2 tie bars too. A latham on the top and a latham saddle style tie bar on the bottom - it also makes a GREAT grab/step when you are in the water.
mittens 04-16-2012 11:12 AM
link to said ladder would be awesome.
FountainDealer.com 04-16-2012 09:18 PM
I have owned a few 342's and bought a slide out 4 step like the outlaw's and bolted it to the bottom of the platform and it worked well...
mittens 04-17-2012 08:06 AM
I am not going to bolt anything to the bottom, but would replace if i can fit a 4 step under that door. just need to know whitch one.
Keith Atlanta 04-17-2012 08:23 AM
http://www.ebay.com/itm/LADDER-TELES...item231c104b89
Ebay - measure yours center to center search 4 step swim ladder. I used a few air tools to modify mine but it works.
