-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Now a Baja member! (https://www.offshoreonly.com/forums/baja/27618-now-baja-member.html)
GameOver 06-28-2002 11:42 AM
Now a Baja member!
Just sealed the deal on a '00 25ft Baja Outlaw!!
The boat includes as follows:
500EFI unfortunatly with a regular Bravo1 drive
Had the SST package but custom paint applied recently
Everything else I believe the 25' comes with, from drive shower to halon fire extinguishers
Runs 72 on the Gaffrig speedo which I believe is on par. Not really moving up since I also run/ran a 25' Checkmate Convincor. Just wanted the bigger motor but ended up getting another boat!
CigDaze 06-28-2002 12:17 PM
Congratulations and Welcome Aboard. It's a big flotilla with a great bunch of boats!
Nice choice, I guarantee you'll enjoy it! :D :cool:
Have you taken it out for a cruise yet? If you did or when you do, let us know how the two compare.
Luv-N-It 06-28-2002 12:54 PM
Gameover,
Congrats on the purchase! Welcome to Baja!!! Let us know what you think of the Baja compared to the Checkmate.
Dock Holiday 06-28-2002 01:40 PM
Nice boat, welcome aboard.
Do not worry about the drive as long as you keep the engine stock.
I have several friends with the same set up and it works great.
Mark
badboats30 06-28-2002 03:17 PM
Welcome Gameover.
seanclong 06-28-2002 03:23 PM
Welcome. Sounds like a great set-up. I, too, would be interested in your comparison between the Baja and the Checkmate. :D
OutlawBayB 06-28-2002 11:30 PM
Welcome the club GAMEOVER!!!
liquid asset 06-29-2002 01:26 AM
Welcome GAMEOVER
Wardey 06-29-2002 03:12 PM
Game - Don't worry about the drive. I ran a 572 cuin 620 Horse monster motor through my Bravo 1. It did "blue" the drive with heat tho but I never broke it. Welcome......Wardey
GameOver 06-29-2002 05:22 PM
Appreciate the welcome guys, and you want a comparison? I'll try
The Checkmate hull is about 1000lbs lighter but it only shows during docking. Almost ran into a pier with the Baja, it takes a little more reverse to get it stopped and going backwards. The Baja also planes considerably quicker which may be due to the huge k-planes. The Check points its nose a little higher while the Baja runs almost perfectly flat. At wot, which is about 8mph more on the Baja, she runs like a champ while the Check required a lot of trim to max out which produced chine walk. However it would warn you unlike the Baja, which bounces around like crazy when you do something wroing. Basically I switched to the outlaw for 'the little things.' Steps to get on the bow, larger engine comparment; although the cabin is smaller I like the dual hatch layout better. The bottom line I suppose is while the Baja slices through most the Checkmate acted nimble and danced from one wave to the other.
Glad I don't write test articles for a mag...its not that easy!
