33 outlaw prop question
What size props should I be running onmy 33 outlaw with 496mags?
What speeds are you seeing now & at what Rpms?
What props are you spinning? WwW |
I'll take a stab
99' w/496's ( non mags)...... 23 mirage +'s. ( must be repowered because the 496's didnt come out til 01') |
24 bravos or 23 mirages.... Lab and that'll change.
And I have a set of older style Mirage's that came on my 320 that are mild lab finished with the Baja cup added they worked awesome on my boat untill I raised the x up 3"!!!!
Originally Posted by HOSSMAN
(Post 3695272)
I think the 3 blades are the better choice on Josh's boat he may increase his cruise speed but top end will prolly go backwards! Just my opinion!!! |
My '99 came with 25 mirage +...even had baja stamped on them..454mags..... I hated the way they handled and went to a hydro 24.. The bravo1 24's also worked well.... Much better handling with 4 blades... It ran a solid 67 on gps with the hydros
Labbed 24 bravos,,,,,,,,,,,,,,,try 22 and 24's though you do have the mag ho right??
I am guessing he has the 375hp mags, not HO's...with HO's you will need either 26's or 28's..prob 26's though.
My 454 Mag EFI came w/ 26's. Still have them if anyone is interested. Running 30's now!!!
Guss |
I have an 04 with HO's and I run bravo 26 and 28's
How about 4 blades Hydromotive 26 Quad IV for twin 375hp 496 Mag
Im running 25 Merc. Mirage with my current 502 mag's, but will need some advise ( help ) when the new motors go in this winter, putting in 540's hoping for 675-700 per side
| All times are GMT -5. The time now is 02:59 AM. |
