-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Replacing shift cable bellow - anybody know? (https://www.offshoreonly.com/forums/baja/277885-replacing-shift-cable-bellow-anybody-know.html)
puzzleboy 06-03-2012 08:38 PM
According to my Merc. manual, it says to just disconnect the end fitting at the engine side (which I've done), remove the spiral wrap inside the boat, and pull the cable out from the transom. It doesn't mention any other operation.
But, as in the pics, the cable at the engine has a barrel and a nut. The barrel looks to be permaswaged on at two points, so not sure about unthreading it.
At the transom end, obviously it's too large to fit through the bellow.
Anybody know how to do this?
http://i28.photobucket.com/albums/c2...y/IMG_2783.jpg
http://i28.photobucket.com/albums/c2...y/IMG_2781.jpg
whoya 06-03-2012 08:48 PM
The threaded barrel should unthread from the brass cable end.
whoya 06-03-2012 08:52 PM
If you don't have the correct plyers for the metal clamp (shift cable boot) you can use just a zip tie, I know marinas that just do this. Thats what on mine and been holding fine for years. Last boat I did I used a pair of plyers the best I could for the clamp and used a small zip tie next to it.
smokin' gun 06-03-2012 09:04 PM
a clever guy can put the shift cable bellows on without taking the cable out .takes a little time but it will go over the end of the cable on the bellhousing side .done it many times when in a hurry and the boats gotta go
puzzleboy 06-03-2012 09:14 PM
How's that? I would think there's a risk of tearing it on the hex, as it's much larger than the bellow i.d.
What's bizarre, is that Merc could have used a much smaller hex there, to enable this easily.
JaayTeee 06-04-2012 04:35 PM
loosen the jam nut, the threaded section where the
barrel is will then screw out.
Biggus 06-04-2012 05:01 PM
Replace the whole aft shift cable as they typically get damaged when pulling it out. Be sure to make a snake from the old inner cable to pull the new one back through. -Otherwise, you are in for a headache getting the new cable back in and routed correctly.
Ted G 06-04-2012 05:13 PM
+1
Unthread that barrel then pull the inner cable out, leaving the outer housing in place. Now thread the inner cable back into the housing from the engine side. When you pull the outer housing hold the inner in place and then thread the new outer onto the old inner and up to the engine. Then pull the old inner and push the new inner up from the transom side.
puzzleboy 06-04-2012 11:37 PM
Just curious, why would it get damaged? Thx!
Biggus 06-05-2012 04:08 AM
Many times you have to tug on it pretty hard to get it out. -If it's factory, there's a spiral protective wrap around the outer jacket down low that gets bunched up when pulling it out. They don't last forever. When it's time for the shift bellows, everything else back there is on the way out too.
puzzleboy 06-05-2012 04:45 PM
I was able to get the spi-wrap off (even the manual had this step), so I'll try to re-use it if it doesn't get damaged. Not cheap, but tired of going to the dealer and waiting on parts.... :)
Flyin-Bryan 05-17-2013 04:47 AM
I agree,do it all at once and be done with it.
92nsx 05-17-2013 07:22 AM
I did mine from the transom end ;). used a ton of grease, can of beer, and bar stool, then slowly worked it over the brass.
