full imco hydraulic steering
i just put full hydraulic steering. I have a question, Is full hyfraulic steering alot different then a steering cable in performance. I mean manuverability. When I had it out and trying to dock it, It felt like i was wrestling a cow and the steering would let loose alittle and jerk. What is normal to expect from full imco hydralic steering.? is it smooth at all speeds or jerky at parking and docking speeds?
what should i expect from this type of steering? |
Only jerky when turning rapidly back & forth.
I have Imco on mine, smooth as can be. Maybe there is still air in the system, just a guess.
im guessing air as well,,,,,,,go lock to lock several times to bleed system and see if it improves.
make sure resevoir is full first obviously |
There is air in the system. It should be smooth, smooth, smooth.
Originally Posted by Expensive Date
(Post 3732091)
Originally Posted by JasonSmith
(Post 3732161)
Don't worry, once it is working correctly you'll never want anything other than hydraulic steering on your boats.
Have the Imco set up on my 24 and love it
i just put full imco on and love it. i have to wonder if you could be having a pump issue, maybe not supplying enough pressure? i only spent about 10 minutes getting the air out of mine and its been good since.
Originally Posted by TW720HVY
(Post 3733073)
been on the water this summer a total of 3 hours and got toed in. the one mechanic was doing wok on the side and it took him for ever to get me the boat back and then steering issues and then blown head gasket, what next the boat sinking to the bottom of the lake i definitly don't like the steering, it sucks the way it is |
Originally Posted by baditude
(Post 3733192)
Originally Posted by regalman4925
(Post 3733200)
Originally Posted by conneroutlaw
(Post 3733858)
do you have a supercharger on the boat? , and if you do, how is the motor holding up with it
(Post 3734088)
Yes I have a whipple suppercharger extension box raised x deminsion shorty imco and steering the boat runs great, Motor is great.
(Post 3734088)
do you tube and wake board off your boat? |
88.7 is the fastest ive seen on gps with a 5 blade may have gone a tick faster but anytime above 80 I concentrate more on keeping a hold of it than looking at the speedo. I cant find anyone that wants to tube behind it :crazy: That and it doesnt have a swim platform .
(Post 3734965)
| All times are GMT -5. The time now is 11:24 PM. |
