-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   WOT with hatch open (https://www.offshoreonly.com/forums/baja/28092-wot-hatch-open.html)
29 OUTLAW 07-06-2002 08:29 AM
WOT with hatch open
Yesterday I had an opportunity to make a WOT run with the engine hatch cracked open 2” in accordance to OTIS311’s suggestion.
Results: I made two passes. One with the hatch closed. One with the hatch open and flame arresters removed. I tried hard to duplicate the conditions one each pass (flat water, same starting point, same direction, etc). The pass with the hatch closed saw 76.1 on gps. The pass with the hatch open and arresters pulled saw 76.9 on gps.
Conclusion: Who knows. Did the open hatch make a difference? Did the absence of flame arresters make a difference? Was it just a case of two passes yielding two different speeds? If I knew it was the flame arresters, I would buy two K&N’s tomorrow. If I knew it was the hatch, then that’s too bad since I just get a bad feeling riding with it open. Also – with the hatch open the handling at top speed seemed to be a lot more squirrelly. May have been my imagination but I can’t help but wonder if it had something to do with all that air rushing into the engine compartment with no place to escape causing the ass end of the boat to do strange things.
Note: Both speeds posted above are below my best of 77.2 but I attribute that to the fact that it was 97 degrees out yesterday vs. the low 80’s during the 77.2 run.
Johnny Bravo 07-06-2002 08:43 PM
I've tried the same thing on my 25 outlaw and opening the engine hatch doesn't work.
29 OUTLAW 07-06-2002 10:52 PM
By the way, if any of you guys with twin engines decide to pull the flame arrestors off and run with the hatch open at WOT, the noise sounds so sweet. It just screams
liquid asset 07-07-2002 06:05 PM
I did the same this weekend and saw .5 faster with the hatch cracked open
Brad Perry 07-08-2002 09:25 AM
Hey liquid,
Are you sure that wasn't caused by a weight reduction due to the recycling of beer from an onboard location to overboard one in the time between tests??:D
Couldn't resist!
liquid asset 07-08-2002 06:26 PM
Thats a good possibility;)
Allan4 07-08-2002 07:43 PM
I disagree, running with the hatch open with both the old and new motors gives and instant 100 rpm and about 1 mph. I've seen it enough times, so I know it works on my boat. In theory plus with two different motors, you guys have to have seen some gains. Later. A4
liquid asset 07-08-2002 09:46 PM
I may have got a little moreif I would have opened it more but I was afraid the wind might catch the hatch
Luv-N-It 07-09-2002 08:10 AM
Before this thread, I've opened mine out of curiosity to see if there would be a performance difference. I opened mine about 2" and found that I instantly gained 100 RPM and 1 MPH.
I have an 272 w/502 MPI.
Brad Perry 07-09-2002 09:25 AM
I've got a sawzall you guys can barrow!
Pretty soon every boat on the lake will be running around with the hatch open, staring at a GPS........:rolleyes:
