Kill switch/lynard for a 88 baja..
I want to put in a safety laynard on my 240 sport..It has a 96 502 in it..what wires do I need to connect it between?
I put mine in the ignition wire path after the key. In theory, you should be able to remove your ignition wire from the key, put it on one side of the kill switch, then run a jumper from the other side of the kill switch to they key where the ignition wire used to go.
Keyswitch > kill switch > ignition |
Where can you buy a kill switch?
what color wire did you interupt it on c-deezy?
Originally Posted by mgoblue06
(Post 3751827)
Amazon.com |
Originally Posted by stlliberator
(Post 3751839)
Red - +12V from harness Yellow - Starter Purple - Ignition |
| All times are GMT -5. The time now is 04:01 PM. |
