-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Advice to put 250 sport in 80's (https://www.offshoreonly.com/forums/baja/288578-advice-put-250-sport-80s.html)
SidneyW 12-06-2012 10:19 PM
Can anyone tell me what it would take to put my Sport 250ES in the 80's ? I currently am running a 468ci roller motor with approx. 500hp. Runs 70mph on gps. What do you guys think?
Nightlife1970 12-06-2012 10:51 PM
What drive do you have? Is the x still stock? Either way bet you are looking at 800+ to get that boat to that speed.
SidneyW 12-07-2012 06:33 AM
Does have the stock X. It has a later model Bravo with the low water pickup. When I purchased boat, it would run 62 gps. And when I built current engine, that pushed it up to 70 turning a 24 Bravo 1 5600rpm.
whoya 12-08-2012 04:29 PM
Around 800hp for a true GPS 80Mph
obnoxus 12-08-2012 07:09 PM
Check the bottom with a straight edge,,,,,most 250's had a big hook
bajabob 12-09-2012 07:05 AM
hear me baby my 240sport 540 dart with 600hp dyno http://www.youtube.com/watch?v=2Kojm...eature=related now i have 718hp . .put a 572 with 650hp will put you in 80
SidneyW 12-09-2012 01:34 PM
could you please explain with further detail about the hook and exactly how to check this? Thanks
Unlimited jd 12-09-2012 01:42 PM
I agree here, I had a 240 with an imco -2" lower, 26 bravo1 prop, blueprinted hull
510" big block making about 625 it did 78 with half tank of fuel and 3 people on board.
Nightlife1970 12-09-2012 04:51 PM
The 250 is a much bigger boat than the 240. Atleast it looks like a much bigger boat to me in person.
SidneyW 12-09-2012 10:29 PM
A 250 is a much larger and heavier boat than the 240. Anyone know the weight difference?
