-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   prop/rmp ? (https://www.offshoreonly.com/forums/baja/290687-prop-rmp.html)
conneroutlaw 01-27-2013 05:17 AM
prop/rmp ?
I have a 1997 outlaw sst with a 502 and a m1 procharger.
The boat came with a labbed 4 blADE spinelle prop. The owner I bought it from did not know the pitch. I have no idea on the pitch. The prop runs great with the boat. The problem is the chip in the rev limiter is for 6000 rpm. I hit the rev limiter at 75 mph. the boat did 80mph origionally before i hade the engine tuned up and made stronger. Now i hit 75 mph and i bounce of the chip.
My question is what prop and pitch do i get to lower my rpms and be able to run the boat wide open and have lower rpms, say like 5400rpm or lower. Also when i use my trim tabs i hit the rev limiter quicker too. What prop and pitch does any one suggest, to help me accomploish this take if it is possible. I just am trying to make it safer for running my engine and helping the durablitiy and longevity of it. And also dummy proff it for me. I am not an engine guy. All suggestions are appreciated. sorry for the book i wrote
thanks
jj
baditude 01-27-2013 01:01 PM
Id suggest a 28 bravo 4 blade to try if you drive is at stock height.
fastscarab22 01-27-2013 03:04 PM
I might but the old spinnile from you
conneroutlaw 01-29-2013 02:04 AM
I don't know the pitch on it. The prop is not marked that i can tell
conneroutlaw 01-29-2013 02:05 AM
The drive height is stock. Thanks what do they run?
baditude 01-29-2013 10:14 AM
Im running a higher x demension shorty lower and a extension box. my small prop is a 30 bravo labbed is a little to small on mine so I run a 32 5 blade maximus labbed. so a factory 28 4 blade should lower down your rpms some with the power your making. Id give bblades a call and see what they think.
conneroutlaw 01-29-2013 01:08 PM
Thank you for the info. i appreciate, i am new to this hobbie
