props
Originally Posted by conneroutlaw
(Post 3864161)
hydromotive on ebay from cobra
(Post 3864161)
Originally Posted by RiReuter
(Post 3864241)
Originally Posted by goebel1
(Post 3864278)
Yes...ask for Todd great props
I talked to him on fri morning. Seems like a great guy. I belive he is the owner. He said he can do exactly what i want , and he thinks what i am trying to do is a great idea with my boat |
(Post 3864313)
What # of blades and pitch are you looking for?
Heres my situation. i want to drop my rpms from over 6000 wide open, to 5600-5800 at wide open speed and run trim tabs all the way up and my out drive at normal height, and still be able to tube and knee board. i am running to high of rmp with my rebuilt motor and it is either change my prop or get a different cam shaft ( i believe that is what my mechanic suggested) the prop is a much cheap route to take. i called him and explained to him my needs and desired out come and he said he may beable to do it wirth a stock prop, I will find out in the spring when i take it to him for a test drive in twinsberg ohio. any props and cons with him, any suggestions? |
(Post 3864531)
Don't know?
That sucks that you don`t have a throttle to control rpm.. yup I think a cam or prop is the way to go for sure.. Have you looked into a drive brake? It also slows down the rpms. just adds a pedal like in car...
(Post 3864917)
What Hp do you have what GPS speeds at what max RPM and what prop and pitch.
i have a 1997 24ft baja outlaw sst with a high performance 502 v8 andf a m1 procharge top speed before rebuild was 80mph don't rember the rmps now after build i am at 75mph/ 6000 rpm and have still room to go on the throttel no gps prop came with the boat , spinelle 4 blade, can't find the picth on it for the life of me, it was labed and cupped so no numbers thats what i have bought it used, and the second owner new nothoing about the boart he sold to me, i am trying to find out more and more every day on my own |
Originally Posted by ICDEDPPL
(Post 3865031)
(Post 3865031)
(Post 3864278)
[email protected] |
| All times are GMT -5. The time now is 09:00 PM. |
