-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   New Baja Owner (https://www.offshoreonly.com/forums/baja/292430-new-baja-owner.html)
puzzleboy 03-08-2013 10:24 PM
Compression check will verify top end health.... Some are good for 700-900 hours, dependent on care.
X2 on the impeller- do it. My gimbal blew last year at 170 hours. Did full bellows and water line replacement also .... Lotsa fun!
Originally Posted by 92nsx (Post 3881482)
500 hr on the 502. Start thinking about rebuilding the top end ;) Install new impeller on sea pump (cheap $50 or less for parts) and check out bellows and gimble bearing.
whosfuelinwho 03-15-2013 08:22 AM
I will check out the compression this spring. I got a warranty with the boat and the dealer seemed really good to deal with. I will definitely changed the water pump. I did that on my old boat regularly as well. It was an omc drive and was super easy to change. Not sure where it is on the merc. I had a survey done and apparently the bellows and gimble bearing were checked as much as possible.
