-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Baja 38 Special questions (https://www.offshoreonly.com/forums/baja/295123-baja-38-special-questions.html)
BAJAJOHN 04-23-2013 02:29 PM
Just got a '95 38 special and have a couple questions. Where can I get help with finding some part numbers? The starboard side trim cable is jammed up bad and I need to replace it. And there's a momentary rocker switch on the passenger side that I can't figure out what it controls. Any help would be great!
hammer01 04-23-2013 02:36 PM
Contact the service dept nearest you that used to sell Baja. There are quite a few of them out there. A good service dept in Chicago was Grand Sport Center in Morris, Illinois. Their serv manager was very resourceful and they carried a lot of inventory. Good luck.
jamontes 04-24-2013 09:44 AM
Here are the Teleflex (Morse) cable PN's. The ( ) numbers at the end are the length.
Throttle
S-D32377-003-0276-0 (23)
P-D32377-003-0300-0 (25)
Shift
S-D32377-003-0264-0 (22)
P-D32377-003-0288-0 (24)
Drive
S-D32377-003-0288-0 (24)
Trim Tab
S-D32377-003-0252-0 (21)
P-D32377-003-0312-0 (26)
I have a complete set with 200 hours on it sitting in my garage. I will ship all of them to you for $125 bucks if you want them. The momentary rocker... Where is it located on the passenger side? Congrats on your 38 Special... We have a 93 model that is about to get a fresh pair of blown 540's. If you have any questions feel free to PM me. I am no expert, but have spent the past 6 months rebuilding and restoring this rig.
BAJAJOHN 04-26-2013 01:09 PM
Thanks for the info. I found part numbers on 4 of my cables and they are not the same length as your numbers at all. Weird? I do have that part figured out though.
Here's the switch on the passenger side that I can't seem to figure out.
http://www.mapmotorsports.com/images...pics/photo.jpg
jamontes 04-26-2013 01:16 PM
Sent you a PM. Could that be a cockpit speaker on/off switch. I do not have anything like that.
jvthundercat 04-26-2013 06:45 PM
Must be an add on, I do not have or have seen a switch there.
jvthundercat 04-26-2013 06:54 PM
Throttle
Shift
Drive
Trim Tab
Sent you a pm on those cables. When My drives got stolen last month, they bent a K-plane cable in half as well.
