Shore power problem on a 35 Outlaw
Im not getting power to the breaker panel on my 35 outlaw. Does anyone know of a fuse or breaker between the power inlet on the transom and the AC panel in the cabin? Thanks for the help.
It's probably a bad ground. Take the panel out, loosen all the grounds and retighten them.
Pull the plug out of the side of the boat. Sometimes too many wires can get tywrapped to them and when hanging and hitting waves it will pull the wires out of the back. If they look good you can check he continuity while its out.
Thanks for the ideas, I will check both today and reply
Originally Posted by Fordman08
(Post 3974660)
Check for rat droppings? Those lake rats will chew right through wiring.
[IMG]http://i388.photobucket.com/albums/o...eatingwire.jpg[/IMG] |
I finally got it fixed. There is a breaker on the port side under the rear seat hidden behind a battery. You can not see it, I followed the wiring to it. It just needed flipped back on. Thanks everyone for the feedback.
| All times are GMT -5. The time now is 04:42 AM. |
