-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   05 baja 25. internal engine issue 496 ho.. help ! (https://www.offshoreonly.com/forums/baja/301392-05-baja-25-internal-engine-issue-496-ho-help.html)
chevalcabre 08-13-2013 03:21 PM
well, i have a good one i am dealing with and can use some expertise from some who may have lived a similar issue..
115 hrs only. all original...
cylinder 3, has 165 compression. it gets spark + fuel.
the plug is always wet.seems like it isnt burning the fuel.
then the starter broke it's plastic internal gear.
we believe it hydro-locked on fuel that went un-burnt and forced the starter to give away.
seems like the exhaust valve isnt opening..
can it be the rocker that loosened up ? and the push rod isnt doing it's job ?
.i seem to hear some minor internal minor noise only when i run the motor with that spark plug connected. when i run the motor with that plug not connected to the spark wire, runs smoother..
again, it seems...
did anyone ever have any similar symtoms on their 496 ?
Wasted Income 08-13-2013 04:09 PM
Maybe it wiped the exhaust lobe on that cyl? Pull the valve cover and crank it over to see if it's moving, and how far.
Could also maybe be a stuck open injector? Maybe try swapping that injector to a different cylinder to see if the symptoms follow that injector.
chevalcabre 08-13-2013 05:11 PM
Removed the valve cover. Found a rocker where the push rod went right through ! What could have caused this ? The exhaust valve wasn't opening...
TWIN-SPINS 08-13-2013 05:48 PM
had a similar problm,with over fueling,,,did the same as yours,,,push rod shot out past the rocker arm,,i heard a ping while i was trying to start it,,,,a new lifter fixed the problem,,,,,when we tested the old lifter,, the plunger would not push into the lifter at all,,,acted like it was a solid lifter
