-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Outlaw 24 vs Outlaw 25 (https://www.offshoreonly.com/forums/baja/309322-outlaw-24-vs-outlaw-25-a.html)
cire 03-04-2014 10:21 PM
Can someone shed some light on a 24OL vs a 25OL. Looks like 24 was produced up to 98, with the 25OL being introduced in 98 as well. 99 was only a 25OL.
Anyone have any input on what the advantages of the 25 over the 24 is besides the obvious. Hull design different? Etc..
Thanks!
c_deezy 03-04-2014 10:39 PM
The 25 has a lot better access into the cabin. Other than that they are pretty similar. Having been in both and owning a 240 (the same hull as the 24 Outlaw), I would prefer a 25.
cire 03-04-2014 10:44 PM
Yea, that's what I was gathering from the pictures. I'm getting ready to buy my first Baja and the 25OL is right at the budget limit I was trying to keep. What's another 5k... sigh..
Thanks for the info.
Crossett 03-04-2014 11:28 PM
25's have a notched transom, 24's don't. 25's weigh a little more and are just a tad slower with the same power. Easier cuddy access. Larger benches in cuddy, smaller berth. Better/newer looking dash. I think only a handful of the early 25's had the ****ty fiberglass swim platform the 24's do, most have tubular aluminum platforms.
Crossett 03-04-2014 11:29 PM
If you can budget 30k check out Active Thunder 25' tantrums. I'd take one of those hands down over a 24/25 outlaw.
cire 03-04-2014 11:35 PM
Thanks for all the feedback. Appreciate it. Buying another boat is stressful! I forgot how much pain I went through last time I did this.
nailit 03-05-2014 08:34 AM
4 Attachment(s)
25ol was a great boat, moving up from a 21 degree Larson, it was like getting on a yacht! took rough water very well. Both boats have 24 degree V and will have a good ride, ultimately the 25ol, depending on graphics, will look a lot more modern (newer!!). Don't worry about the tall guy.. he is actually 6' 9.5".. so boat just looks small with him! I'm a foot shorter ! :angry-smiley-038:
For example, This was our 99 25OL
[ATTACH=CONFIG]519780[/ATTACH]
[ATTACH=CONFIG]519781[/ATTACH]
this is our 98 33OL that I recently updated the colors on!!
[ATTACH=CONFIG]519782[/ATTACH]
[ATTACH=CONFIG]519779[/ATTACH]
XT-Innovator 03-09-2014 04:12 PM
The 24 are a carpeted plywood cockpit floor that is filled with foam and the 25 floor is fiberglass and molded with the deck. The 240 Sport/Outlaw hull was the starting point for many other models including the 25 OL. The 25 bottom design is just the 24 with 12" added to the rear running surface and that small notch on the 25 is more a gimmick than function, like the the "Speed Rails" that were carved into the chines. The other models that were designed from the 24 hull were: 250 Sport/270, 252, 272, and Islander versions.
spark plug 03-18-2014 07:15 AM
I remember someone telling me the 24 had a higher degree dead rise than the 25. Was told the 24 rides better in rough water but is slower than the 25 with same power. I love my 24, however the styling of the 25 is a newer look, and def the biggest thing is the access to the cabin. that's prob the one thing I really don't like is having to crawl into the cabin.
mo3d 03-18-2014 07:49 AM
I'm getting ready to put my '97 24 SST Outlaw on the market if anyone is interested. Freshwater boat with 454 Mag 365hp (carb), 180hrs, with FULL stand up camper canvas (real nice for overnighting or bad weather), on trailer for $20k
Main requirements are:
1) Nice hefty motor of course. 5.0L won't cut it. Singe engine 454 or 502 is my wish.
2) Some cuddy cabin space (possibly with room for a porta potty under the hull seat for my daughter)
3) Big enough to handle the lake when it gets choppy (Lake Lanier in Atlanta is known for is busy chop) so 24+ is what I'm looking at
4) Budget - 25k max.
XT-Innovator 03-19-2014 09:38 PM
Originally Posted by spark plug (Post 4091629)
I remember someone telling me the 24 had a higher degree dead rise than the 25. (NOT TRUE) Was told the 24 rides better in rough water (NOT TRUE)but is slower than the 25 with same power. (NOT TRUE) I love my 24, however the styling of the 25 is a newer look, and def the biggest thing is the access to the cabin. that's prob the one thing I really don't like is having to crawl into the cabin.
Who was this guy? The only thing that could happen is the either model could be faster depending on all the varibles.
The 24 has higher "freeboard" and maybe that confused him, and maybe the foam filled wood floors feel a little more solid than the hollow fiberglass floor in the 25ol, but if anything the 25 should ride better due to the added foot in length.
XT
spark plug 03-20-2014 07:15 AM
ah cool, thanks for the clarification. so power being the same, which is the faster. and which is heavier. I have a local friend with a 25 outlaw with stock 502. says he can run 73. My 24 with a 525sc that dynode 570p would only run 70. hull difference? or am I missing something.
XT-Innovator 03-20-2014 07:33 AM
Both boats might not be the same weight now as when they were new. When Ebay Ed pulled stringers and floor boards from the "cabin area" of his 272 they were SO heavy from moisture you could hardly lift the sections. Weigh both boats and run them side by side. Your 70 mph boat might out-run his 73 mph boat? That sounds a little high for a (stock) 502 anyway. Your "x" dim. might be lower on the older boat, and are you running a Mirage, or Mirage Plus? As far as hull difference put his 25 on your 24's trailer and it will fit like a glove except for the 12" hanging off the back.
XT
