-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Broken teeth on upper gears in Bravo One outdrive (https://www.offshoreonly.com/forums/baja/315575-broken-teeth-upper-gears-bravo-one-outdrive.html)
cire 07-21-2014 05:39 AM
Hey guys.. Need some advice please. We just finished a poker run this weekend but unfortunately my run ended sooner than later. I have a 272 boss with a 502 mag and bravo one. As I pulled into the first checkpoint and backed off the throttle, there was a loud knocking coming from what seemed to be the drive. We parked the boat and pulled the drive off yesterday to inspect. As soon as we pulled the bottom screw I could see shavings. After digging deeper we found broken teeth on the upper gears. Looking online, it looks like a new upper gear set is about 1700. Any recommendations on getting them any cheaper? Also are there any higher end/performance grade gears I should consider since I'm already in this for a decent amount of $$ it looks like.
Thanks for your input.
Tinkerer 07-21-2014 10:08 PM
You probably did a LOT of damage to the lower also. Look for a new used Bravo drive.
