-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Engine Vent Cracks (https://www.offshoreonly.com/forums/baja/315603-engine-vent-cracks.html)
Bajadreamin 07-21-2014 11:27 AM
Engine Vent Cracks
05' 232 Islander, Over the past two seasons I have noticed the cracks around the engine vents getting worse, They have not protruded out into the gelcoat. Reading this and other forums sounds like this might be a common problem. I was wondering if anyone has been able to successfully fix this issue? Will it continue to get worse? Is there a more flexible joint sealer I could have put in between the vent and the boat?
