Adding AC to 2004 Baja Outlaw
I am thinking about installing AC on my 2004 Baja Outlaw has any one installed an AC unit on a performance style boat? I would love for some advice. It would be really nice for sleeping on the boat.
https://www.dometic.com/bd10b370-ad7...59e03737.fodoc |
I installed one on my 1991 Baja 260 and also my 2003 302 had one factory installed. They were great. On both boats, had a 5000 btu Mermaid with reverse heat, although I never the heat side. Had shore power and factory breaker panels on both. Used a Honda 2000i gen on swim platform or just in front of the cockpit for power when not at docks.
I don't have true shore power but I have a plug on the back that runs to a 3 bank onboard ProNautics battery charger and a Honda EU1000i will run it so worst case if I had to run that the next day for a few hrs. to charge the batteries that would work. I have 4 AGM series31 batteries. 2 are for the 2 engines and the other 2 are for accessories/stereo. I should be able to run this all night without a problem.
If your interested I have a air conditioning system that came out of a 38 special I'm parting out.
I've never tested it but would assume it works. Firehill might know as it was a guy in their group whose boat I bought after he removed power and drives. If your interested let me know, I'm fixing to get the interior of the salon out next. See ya, Kelly |
Where do you plan on mounting it?? Seems like it would take up a lot of storage space. With there not being much to begin with!!
These units mount under the berth in the foksal.
The return air is centered towards it under the setee. You'd be shocked how little real estate they occupy in the storage locker beneath.the bunk. The duct work fishes under the setee and discharges in the salon vents and the forward stateroom or V-berth. In a 29ol there may not be room to place a vent there in the berth. IMO, nothing beats ac on board even if you live up north and good units reverse the gas and make heat too. Keep your boat and purchase mine LMAO!!! See ya, Kelly |
Originally Posted by huskyrider
(Post 4203915)
See ya, Kelly Congrats again to you and your bride. There's plenty of time in y'alls lifetimes to hop back in again. Never ever forget or forsake your family's priorities. See ya Kelly |
Eddie from lake ozark marine installed one on a hustler I believe few years back, it was on JMS's boat I believe on MWBP forum
Cant remember his OSO handle - he was a boat painter from TX- Austin maybe? somewhere but he had a 29 Outlaw all white. Install AC in it. If I remember correct it took up one of the closets. Had the thing all plumbed in and put a Honda Gen back on port side between stringer and hull. Worked great and he said the 1 or 2 gal tank would run damn near 8 hours I think. Was a Very nice set up.
Great installation :grinser010:
Dometic Marine Air Conditioning has some smaller self-contained units that may fit, but I'm not an A/C expert. The ECD goes as low as 6k BTUs, but is a bit bulky. The Dometic Turbo I believe may go as low as well, as has a slightly smaller profile. Best of luck on your mission ! |
I installed a/c in our 33 Outlaw. The unit is under the v-berth and I have 2 ducts that come out behind the couches. Mine is a 5,000 btu and it works great.
How do you take up couches? Can't figure out how they come out
Has anyone used the 12 volt AC's
Looking at one was curious of any real world experience |
ive also seen a few people install the portable units for a house not the window kind but the kind that stand up and you use a vent hose. They have some real small ones out there and you don't have to worry about water dripping. Just plug it in and fit it to vent hot air outside wherever you like. Might not be as clean looking but probably less than 200 bucks and a few mins to install.
| All times are GMT -5. The time now is 08:44 PM. |
