-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Fresh water pump (https://www.offshoreonly.com/forums/baja/320187-fresh-water-pump.html)
SNSTER 11-16-2014 12:27 PM
Fresh water pump
Anybody know which freshwater pump is a direct replacement for the one on a 2000 38 special? Mine no longer has any markings on it so I can't identify what brand and model. Thanks
First Gun 11-16-2014 02:23 PM
Pics might help with an id
Baja226sport 11-16-2014 02:58 PM
Do you mean for the sink?
SNSTER 11-16-2014 03:00 PM
http://i58.photobucket.com/albums/g2...psadcde9bc.jpg
SNSTER 11-16-2014 03:01 PM
It is the pump that supplies both sinks and toilet
First Gun 11-17-2014 07:25 AM
Looks like a older jabsco or Johnson pump ....shut flo aqua king would be a close replacement pump for this the 3.0 version looks to be the best fit
SNSTER 11-18-2014 11:47 AM
Ok I found some info. I will update here in case it can help somebody else. The pump pictured came out of a 2000 Baja 38 Special. It is a jabsco 44010-2. This is no longer in production so I contacted Jabsco. The replacement is model 31395-0392. This is the 12v 40psi model. Hope this can help somebody else.
jvthundercat 11-21-2014 05:45 AM
thank you
SNSTER 12-03-2014 07:01 PM
Update that pump won't work. Flows the wrong way and can't be changed
